How easy should it be to turn the front wheels?
Old Nov 12, 2008 | 07:11 AM
Fasteddy_98
Default How easy should it be to turn the front wheels?
Hello again, same guy that's posted twice before about my gas mileage dropping from 360/tank to 260/tank. I've done all of the things recommended before - thanks for all the responses - and still have low mileage. I took someone's advice from here and put my car on jack stands. Putting the car in neutral, I tried to turn the front wheels. Very tough! I could move them but it took a significant amount of effort. Is that normal? No brakes either. Is it possible when my tire shredded at 85 mph it damaged the internals? Thanks in advance for the responses.
2005 Accord V6 EX
Old Nov 12, 2008 | 08:18 AM
falkore24's Avatar
Default RE: How easy should it be to turn the front wheels?
Definitely possible!!! Gotta get that checked out!!!
Old Nov 15, 2008 | 04:50 AM
Swing the brake caliper out & remove brake pads. That will tell you if its dragging brakes vs. bad wheel bearings.
Put the tranny in neutral, but keep in mind you still have to turn the axles & part of the differential. You can feel the momentum of those, & there is some drag from the axle seals in the tranny.
Its been awhile, so I suspect dragging brakes.I expect abad wheel bearing would get worse & might have destroyed itself by now.
You may need to file the brake pads (their steel backing plates) so they dont wedge stuck into the caliper brackets? Or maybe the caliper slide pins are seized?
bmacb
Dec 28, 2007 10:09 AM
Mzanuel513
Nov 15, 2007 05:14 PM
davidjata
Apr 7, 2006 07:31 PM
mrstangblb
Dec 24, 2005 12:52 PM
