how to fit an exhaust
Old Jul 17, 2007 | 07:31 PM
mr studio
Default how to fit an exhaust
94-96 accord aerodeck 2.2i es manual/petrol (wagon/estate)
replacing central and rear silencers.
hi,
could anyone please give advice on fitting the above two parts to my vehicle?
what i am most confused about is do i need to use the exhaust paste on the gaskets? or does everything just bolt together? i presume the presence of the springs in the joint means there should be room for movement between the parts? also the exhaust paste states "not to be used on catalytic converters"??
i have the following parts:
central silencer (behind cat)
rear silencer
exhaust paste
gasket (looks like hardened wire wool)
gasket (steel metal ring)
thanks in advance.
Old Jul 18, 2007 | 08:43 AM
tkundert2's Avatar
Default RE: how to fit an exhaust
Not sure what advice you are seeking but I wouldn't use the paste upstream of the CAT, which shouldn't be an issue since the silencers are both downstream. Yes the springs are there to allow for some movement/expansion.
45below
Dec 31, 2010 12:51 PM
98accordman
Oct 24, 2010 10:34 PM
jacmo01
Nov 21, 2008 09:28 AM
abelh7
May 1, 2006 02:28 AM
gabelmatt
May 10, 2005 09:44 PM
