how to fix leak on transmission
Old Aug 15, 2007 | 11:23 PM
kennilope's Avatar
Default how to fix leak on transmission
I think my transmission is leaking.... going to check out where it is tomorrow
any suggestion to fix the leak??
or do i have to bring to a mechanic??
Old Aug 15, 2007 | 11:31 PM
deserthonda's Avatar
Default RE: how to fix leak on transmission
ORIGINAL: kennilope
NO offense my friend ,, but read what you are asking and then see if you think we have a clue on how to fix it..
what is leaking ?? the case?? a hose?? axle seal ?? AT?? 5 sp ??
Old Aug 15, 2007 | 11:41 PM
kennilope's Avatar
dont know where the leak is at...... i saw it by the radiator....
just wondering
Old Aug 16, 2007 | 08:44 AM
00AccordLX5spd's Avatar
Registered User
If you can locate exactly where the leak is, maybe someone can help you. But, we can't unless we know where the leak is coming from. I imagine the best way to do this would be to jack the car up and support it on jack stands, then put a clean piece of cardboard under the trans where you think the leak might be. Then wait for it to drip onto the cardboard and try to see if you can look straight above where the fluid just dripped, then maybe you can pinpoint the leak.
Also is it a 5spd trans or an Auto?
Old Aug 17, 2007 | 10:57 AM
kennilope's Avatar
Fixed the problem... it was by the radiator... just tigten it up......
jkowtko
Jul 23, 2018 08:41 PM
phatboyslim2012
Aug 7, 2012 01:55 AM
rykertest
Feb 7, 2012 11:41 AM
knadd
DIY Answers.
Sep 11, 2010 05:54 PM
mrstangblb
Dec 24, 2005 12:52 PM
