How to get better gas mileage 2009 4 cyl accord wauto
Old Sep 10, 2013 | 09:43 PM
cyberplaid's Avatar
Default How to get better gas mileage 2009 4 cyl accord wauto
I want to increase my mileage on 2009 accord coup 4cyl auto. It seems to shift at 2000 RPM from 1st to 2nd but I cannot get it cruise at low RPMs in D like 900RPM.
Any help to make adjustments are welcomed
Old Sep 11, 2013 | 08:41 AM
You can't change gear ratios or shift points to lower rpm. All you can do is slow down. RPM's are set to optimize engine power/efficiency/acceleration. Some compromise is necessary to balance competing values.
There are plenty of things to do to reduce gas consumption:
1) drive slower is largest factor
2) avoid use of AC when possible (in Houston that is practically never!)
3) keep tire air pressure at high end of acceptable range, usually about 35 psi
4) driving habits; avoid jack-rabbit starts, resist urge to pass all vehicles, allow vehicle to slow on grades rather than downshift to maintain speed.
Old Sep 11, 2013 | 09:11 AM
shipo's Avatar
If you geared the transmission/final drive to run at 900 RPMs at highway speeds, you'd destroy the engine in a few thousand miles.
As others have said, if you want better gas mileage, keep your foot out of it.
Old Sep 11, 2013 | 06:41 PM
To add: maintenance, get low roll resistance tires when replacing tires, etc.
Old Sep 12, 2013 | 08:25 AM
cyberplaid's Avatar
Thanks to all.
The problems I encounter are when starting from a start rpms run up to 2000 rpm before the first gear change. Also driving down hills the transmission hold the car back therefore there is much less roll as seen with a Camry.
On the highway rpms stay at 1500 rpms in high gear.
This seems to me to be very problematic in terms of better gas mileage.
I have a Camry which is also a 4 cyl it gets much better mileage drien the same way.
No jack rabbit starts, proper inflation, clean air filter, recommended oil, no AC on unless needed and even there it is recommended at times for good gas mileage,
Old Sep 12, 2013 | 09:01 AM
shipo's Avatar
Thanks to all.
Sounds like your car is operating as designed.
AceTheAce
May 8, 2009 02:35 PM
bigrudolph
Jul 4, 2008 01:36 PM
1995accord
Apr 29, 2006 04:32 PM
accordtypeexl
Feb 13, 2006 03:20 PM
