how to install digital cd changer for Honda
** Good Information Member...Thank You For Posting It For The Members **
Digital cd changer for Honda
Honda (White) Cable:HD01
Before connecting any cables to the Digital Music Changer you must set the dip switch to the correct position. Dip-switch must be set before you plug in the Digital Music Changer
Settings for Honda 2.0/2.4/3.0
1 2 3 4
ONONONON
Front of Honda Car Radio Back of Honda Car Radio Honda Cable Harness
Compatible with
HONDA
Accord 2003-2006
Fit
City
Civic
Element 2003-2005
Odyssey 2005-2006
Ridgeline 2006
S2000 2004-2006
Installation Guide:
1: The first and most important step in using Digital Music Changer is setting the dip-switches; this makes the Digital Music Changer compatible with the vehicles it is being installed in.
2: Before the installation, power off the car
3: Plug the Digital Music Changer into your car stereo changer port (usually located behind the radio)
4: Insert the USB disk or SD Card (please consult user manual about setting music files in the USB disk or SD Card)
5: For PC, PSP, MD, Mobile Phone etc aux device, connect it with Aux in port
6: Once the unit is installed, power on the radio, then press the CD button or AUX button, you will then have the following control: Disk+/Disk-, Next track, previous track, Fast Forward & Fast Rewind etc.
7: Press “Repeat” button to switch between MP3 and AUX IN
1 2 3 4
ONONONON
Compatible with
HONDA
Accord 2003-2006
Fit
City
Civic
Element 2003-2005
Odyssey 2005-2006
Ridgeline 2006
S2000 2004-2006
Installation Guide:
