How to lower my 93 2dr accord.
Old Jul 20, 2010 | 10:44 PM
sk8erbui's Avatar
Default How to lower my 93 2dr accord.
what do i need to lower my car? thanks.
Old Jul 21, 2010 | 12:24 AM
g22cd5's Avatar
Supper Moderator
you need about about $600
Old Jul 21, 2010 | 12:26 AM
kris_loehr's Avatar
The short answer is you replace the springs with ones designed to lower the ride height, but then you will want to match the struts to the springs. Some companies sell them as a set which seems like the way to go. You will then need an alignment after you change out the parts and you may need additional parts to get the camber and caster in specs from the change in ride height.
Old Jul 21, 2010 | 12:35 AM
deserthonda's Avatar
taking the air out of the tires would work and it is free.. :-)
the advises you got are good,, you might want to search the net for a complete lowering kit.
it should include springs, struts, camber kits in order to do a proper alignment or your car will wear tires real fast ..
Old Jul 21, 2010 | 12:50 AM
Thumbs up *What Ya Do Is Buy A Set Of These Off Me**
And lower away your ride thru PM only please...
click that image!
Old Jul 21, 2010 | 09:38 AM
sk8erbui's Avatar
Default (how to lower my 93 2dr accord)
so i bought adjustable coilover springs and they just dont look like they will work. the springs are so much smaller, am i gonna need new shocks/stuts as well?
Old Jul 21, 2010 | 10:58 AM
g22cd5's Avatar
Supper Moderator
coilover springs are ALOT smaller if you are comparing them to factory. They are shorter and skinnier too. What coilovers did you buy?
Old Jul 21, 2010 | 08:14 PM
sk8erbui's Avatar
Default (93 2dr honda accord)
i bought some not so great ones off ebay,
1990-1993-HONDA-ACCORD
Old Jul 21, 2010 | 08:30 PM
g22cd5's Avatar
Supper Moderator
ehh I wouldn’t trust them. They don’t even give you a spring rate??.wtf?!?...IMPO don’t use them. Suspension is very very important parts on your car. Don’t cheap out if you don’t have the money to spend to do it right...then stay OEM. Otherwise you WILL have problems down the road. btw ebay coilover sleeves are notorious for snapping. IF one breaks your screwed. You can wreck and hurt/kill yourself and or others.
Old Jul 22, 2010 | 12:50 PM
sk8erbui's Avatar
Default (93 2dr accord)
thanks man, i should have enough for some quality parts. what would you recomend?
