How much is a reasonable dealer charge for a 98 Accord LX/timing belt change & auto trans change?
Old Oct 17, 2006 | 04:44 AM
deserthonda's Avatar
Default RE: How much is a reasonable dealer charge for a 98 Accord LX/timing belt change & auto trans chang
ORIGINAL: drummer1279
sorry...there again from personal experience Ive never had an issue with remanned parts, Im running a remanned alternator in my accord now, I installed it a year and a half ago and its never given me any problem.
no need to be sorry my friend........i also would install a non honda alternator not that i would advice it,, but i would not install a reman water pump ,,the damage would be too costly if it came apart. .but alternator no big deal ..
Old Nov 3, 2006 | 02:03 AM
MichaelEXL's Avatar
Default RE: How much is a reasonable dealer charge for a 98 Accord LX/timing belt change & auto trans change?
The dealer here in Daytona Beach is offering $75.00 off coupon that you can print out at home. I would check your local dealer t osee if they have coupons like that .
Old Nov 3, 2006 | 01:35 PM
YeuEmMaiMai's Avatar
if you are in st louis mo or the sourrounding area you can try JH car care.......the specialise in Hondas....
Old Oct 3, 2007 | 12:42 PM
NeedForSpeed's Avatar
Good thing I found this info at this website, I thought my dealer was ripping me off. They were going to charge me $700 for changing everything - timing belt, water pump, seals ..... the works. I should probably search for some coupons online! This thing is pretty expensive.
Old Oct 3, 2007 | 01:03 PM
00AccordLX5spd's Avatar
Registered User
Check the phone book for Honda Certified shops. They will likely do it for $100 cheaper (with genuine Honda parts)than the Honda Dealers (at least that is the way it is where I live.)
Old Oct 3, 2007 | 01:37 PM
smaglik's Avatar
resurrected!
Old Oct 3, 2007 | 02:09 PM
  #17
spiderbait's Avatar
i just got my timing belt done at the dealer a few weeks ago. it was $650 but they were running a special for september. normally it would have been more than $100 more. they also chnaged the water pump and all the normal things. also got 5 "free" carwashes. a second quote from a non-dealer shop was $600.
Old Oct 3, 2007 | 03:11 PM
  #18
falkore24's Avatar
not bad
Old Oct 7, 2007 | 04:54 AM
  #19
srlance24's Avatar
Hey, I'm new, first post. I have a 93 accord EX. 160,000 miles, 100,000 when i first bought it and timing belt wasn't changed before I bought it. Recently I looked into a timing belt change. Yeah, dealership charges about 600 bucks for it. Even though the manual says to change every 90,000 miles I take a perspective of diagnoising to see if something needs replacing before doing it. (and with 600 bucks riding, I think an inspection is more than reasonable). Anyways, took off the valve cover,top timing belt cover, engine mount, and drivers side wheel. Cranked over the engine manually with a wrentch (counter clockwise) and inspected the belt.... perfect condition. Labels and all still neatly on there.
I'm not advocating people skip regular maintence!! But with lots of $$$ on the line, its definitly worth a couple of hours to inspect and diagnois.
Old Oct 7, 2007 | 10:33 AM
  #20
Tony1M's Avatar
ORIGINAL: srlance24
Did you change the belts? If not, those pretty belts will be snapping before you know it.
If nothing else, at least change the timing belt. That way you're protected from engine damagewhen everything elsesoonbreaks, wears out, or springs a leak.
