how to replace a bulb under the dash?
Old Jan 29, 2007 | 10:59 PM
tiffany's Avatar
Default how to replace a bulb under the dash?
It looks like a bulb under my speedometer is out. The manual doesn't mention anything about changing a bulb under the dash. Does anyone have any experience or can point me in the right direction about how to replace a bulb under the dash?
Thank you!
Old Jan 30, 2007 | 01:42 AM
deserthonda's Avatar
Default RE: how to replace a bulb under the dash?
it might require to remove the instrument cluster ,, but first things first ..which bulb is it exactly ??
why don't you input the year and model in your signature so we all know what you need help on. .and give us a bit more details
Old Jan 30, 2007 | 03:57 PM
tiffany's Avatar
Sorry about that...2000 Honda Accord 2-dr EX.
Its the higher RPM numbers and the lower speeds on the speedometerthat are dim as if a bulb is burnt out.
Old Jan 30, 2007 | 04:08 PM
sir_nasty's Avatar
I believe in our DIY section is a writeup in instrument guage cluster replacement. I'd look through that and it should show you how to remove it and then you just need to replace the bulb
Old Jan 30, 2007 | 05:20 PM
tiffany's Avatar
I searched for "instrument gauge" and "instrument cluster" in the DIY Section and got zero results.
Old Jan 30, 2007 | 05:39 PM
sir_nasty's Avatar
it was called dashboard guages *L* sorry about that but here it is
https://www.hondaaccordforum.com/DIY...m_25695/tm.htm
Old Jan 31, 2007 | 11:52 PM
tiffany's Avatar
Thanks! That is definitely good information! Now I know how to get out the dashboard section.
The link also says: "The 7th Gen Accord has LED soldered to the circuit and its hard to change the bulbs." Do you know if that's the same scenario for 6th generation Accords? I searched the forums but didn't get any results regarding how the bulbs are attached to the circuit board. Do you know how the bulbs are attached to the circuit board?
chafey
Jan 10, 2009 04:38 AM
pejaypreston
Mar 15, 2008 04:36 AM
humblehyper
Oct 9, 2007 05:04 PM
sskkf
Jan 19, 2007 04:23 PM
mngantung
Aug 5, 2006 02:22 PM
