How to replace climate control light of Honda Accord V6 2010 has
Old Mar 25, 2013 | 05:19 AM
candoan's Avatar
Smile How to replace climate control light of Honda Accord V6 2010 has
Hi everybody, I'm a new member here. I have reading a lot of helpful info on this forum. Today I really need help from some experts on problem of my car.
I have honda accord V6 2010 and the light bulb of the climate control wes dead so I could not see or change in the early morning.
I wonder how to replace it and what kind of that bulb and where I can buy it.
Thanks for all your help.
Old Mar 25, 2013 | 07:51 PM
Not sure "which light" you are talking about?
My guess: hondaautomotiveparts.com/auto/jsp/mws/prddisplay.jsp?inputstate=5&catcgry1=ACCORD&catcgr y2=2010&catcgry3=4DR+EX-V6&catcgry4=KA5AT&catcgry5=HEATER+CONTROL
Hope this helps?
Old Mar 26, 2013 | 04:28 AM
candoan's Avatar
Thanks for your reply. Your drawing is right, the light that we can see to change option air flow to face, leg, windshield.., turn AC on/off and defrost rear window. Base on your drawing the light number 5 and 6 would be right. My question is how to replace it, please help.
Thanks for your help.
Old Mar 26, 2013 | 09:24 AM
It probably is not the bulbs, if they are all out. Check the No. 6 fuse (7.5A) in the passenger under-dash fuse/relay box.
Replacing the bulbs require removing the audio unit, which means the center console, center console pocket and dash trim needs to be removed first. But, it most likely is not the bulbs, if all of them are out.
Old Mar 26, 2013 | 09:28 AM
Dr. Drivability's Avatar
looks like some bulbs are replaceable, not sure if they are the ones you are having issues with. the whole control unit has to come out. best to get yourself a service manual. it is fairly involved.
Old Mar 26, 2013 | 09:48 AM
candoan's Avatar
Thanks for the info, what I see is not all the bulbs were out. It's just on the right side with 3 switches are air flow, AC and rear defrost. I check the fuse and it's still good. Do you know how I can have the service manual that shows me how to do it.
Thanks again.
Old Mar 26, 2013 | 09:50 AM
candoan's Avatar
Thanks but do you know how to have this service manual??
Old Mar 26, 2013 | 10:20 AM
buy it
Old Aug 16, 2013 | 06:22 PM
Christopher Brown's Avatar
Maybe you might be able to help me. I have a 2010 accord v6, can i put in the digital climate control. It just has the basic push bottoms with temp **** and fan speed ****. What would be the process to install the digital unit?
SPBAV6
Sep 27, 2013 09:47 AM
rolling
Feb 10, 2011 09:09 PM
pejaypreston
Mar 15, 2008 04:36 AM
raf105
Sep 28, 2007 02:55 PM
greenbean
Sep 21, 2007 03:14 PM
