How replace rear control arm
Old Mar 18, 2006 | 09:29 PM
meazz1's Avatar
Default How replace rear control arm
I have 94 accord and the mechanic advised that the rear control arm is little bent. I am not sure which one, left or right. I will put that on lift soon.
I bought the car from a salvage auction.
How difficult it is to change the control arm? Also, how much am I looking to spend including parts and labor?
Old Mar 18, 2006 | 10:27 PM
lightshow's Avatar
Default RE: How replace rear control arm
if you get it done somewhere...its going to cost more than you want to spend but if you do it yourself its really easy....you just unbolt it! couldnt possibly be easier.....just getting the sway bar hooked back up will prolly be the biggest problem
Old Mar 19, 2006 | 12:28 AM
marbro's Avatar
i think you will want both rear tires removed and the rear up in the air to releave the tention on that sway bar
spudman49
Oct 13, 2008 02:47 PM
mtnbay
Jul 20, 2008 03:22 AM
zero5
Jun 5, 2008 09:39 PM
RoKnAzn
May 21, 2007 06:29 PM
meazz1
Apr 10, 2006 06:17 PM
