hydrolic presure build up
Old Feb 25, 2007 | 02:06 PM
turbomad1's Avatar
Default hydrolic presure build up
i have a major problem on the clutch i have to keep bleeding the slave cylinder every few days as it seems to be presurising the hydrolics can anyone help me on thes questions please
i have took it to a clutch center and they couldnt find any specific problem but i dont think they gave it enough time to build up pressure to be quite honest
it had a clutch fitted not long ago by a friend of my brothers(big mistake) and since then its been building pressure up any ideas
cheers keith
Old Feb 25, 2007 | 02:30 PM
turbomad1's Avatar
Default RE: hydrolic presure build up
oh i fogot to add its a 1996 uk model accord 2.0i es
Old Feb 25, 2007 | 02:47 PM
hondadude's Avatar
Builds Pressure?
As in the Slave cylinder is pushing the clutch pivot arm all by itself?
The only time I've seen something like that is when a "Skippy Lube" guy put oil in a master cylinder.
Old Feb 25, 2007 | 02:51 PM
turbomad1's Avatar
cheers for your speedy reply matey
well what seems to be happening is that its ok for a couple of days then it starts to slip untill i bleed the system when i undo it i get a quick squirt of fluid then its fine again i will drain the system and replace the fluid as they could of put rubish stuff in there i spose
NINETY5LX
Jul 27, 2025 09:33 AM
importnewbie
Aug 16, 2007 05:11 PM
bondandracing
Nov 8, 2006 10:46 PM
MCAccord
Aug 11, 2006 04:48 AM
98Accord220HP
Jun 25, 2006 03:39 PM
