I have tried everything. Car will not start.
Old Feb 23, 2014 | 10:23 PM
  #21
Reflections_ii's Avatar
Ahhh... That sucks... I will look for a leak down test to rent but I really don't want to buy one. If anything I will take off the cylinder head and have it resurfaced. I should have had that done in the first place. If the car hasn't started yet I shouldn't have caused any damage right?
Old Feb 24, 2014 | 09:07 AM
  #22
Roader's Avatar
You've done a lot of work/replaced a lot of parts. Specifically, you removed the timing belt from the camshaft. Are you positive that the camshaft timing is correct? The engine can have low compression if the camshaft isn't in time with the crankshaft.
Old Feb 24, 2014 | 01:09 PM
  #23
I set the timing to top dead center so timing should have been correct right?
Old Feb 24, 2014 | 06:14 PM
  #24
Roader's Avatar
You set the crankshaft to TDC...how 'bout the camshaft?
I'm not familiar with 4th Gen cars (3rd Gen?), but 5th & 6th Gen F-series engines have marks on the camshaft sprocket that have to line of with the valve cover seating surface when the crank is set @ TDC.
A camshaft out of time could very well account for low compression across the board. And it cause the car to not start.
jenjustice
Jul 1, 2012 12:44 AM
Sam Maynard III
May 15, 2012 06:44 PM
dpc386
Aug 9, 2011 10:34 AM
brickballer
Apr 18, 2008 04:25 PM
Nodiesop
Nov 14, 2006 12:44 AM
