I loose breaks when I turn!
Old May 21, 2007 | 03:32 PM
dexter1's Avatar
Default I loose breaks when I turn!
1990 Accord EX. I just replaced the Master cylinder, wheel cylinders and breaks. I had the system pressure bleed. On the drive home I made a sharp turn and lost my breaks. When I straightend the wheelsI regained pressure. I tooled around a parking lot and lost breaks every time I turned hard and regained on the straight. I am baffled.
Old May 21, 2007 | 03:39 PM
sir_nasty's Avatar
Default RE: I loose breaks when I turn!
Is there a drop in RPM's when you turn? Do the brakes go out completely or just work less?
Old May 21, 2007 | 03:54 PM
dexter1's Avatar
There is a drop in RPMs and they work less. Go all the way down to the floor.
Old May 21, 2007 | 04:07 PM
sir_nasty's Avatar
it sounds like your power steering pump is draging down the car.... make sure that your belts are all tight and your fluid levels are all correct, also check to make sure that one of your brake lines isn't getting pinched when you turn.
Old May 21, 2007 | 07:37 PM
Chiovnidca's Avatar
Make sure your axle nuts are tight.
white95accord
Apr 24, 2008 10:05 PM
ZionsWrath
Mar 26, 2008 11:56 AM
diablospollo
Dec 13, 2007 05:06 PM
thunder_x
Aug 12, 2007 04:21 PM
TheBackRoads
Dec 2, 2006 06:17 AM
