I need help
Old Oct 29, 2012 | 10:48 PM
Lorenzo Crespin's Avatar
Default I need help
So I have a 1998 Honda Accord v6 and about a week ago I drove my car to a friends house an when I parked the car I noticed a huge puddle of fluid under it I popped the good and it was power steering fluid? So we started it again and the power stearing want working and u could hear the ps pump grinding and it still overflowed again popping off the reservoir cap off and over flowed again. I just replaced the power steering pump to day and its still not working right the power steering goes in and out and still pops off the cap and leaks out. I have no clue what to do here can anyone offer some advice??
Old Oct 30, 2012 | 08:59 AM
Sounds like air is getting into the system and causing the issue. Check the lines (all of them) for leaks.
Old Oct 30, 2012 | 11:01 AM
Especially check the low-pressure hose that goes directly from the bottom of the reservoir to the pump. That's the only one that would have suction. Otherwise you'd have fluid leaking out, not air sucking in.
Check & clean the PS fluid reservoir. In the bottom of the reservoir is a fine mesh screen, usually submerged in the fluid. If that's blocked with crud, it makes it more likely for the system to suck air in.
99accordf23a5
May 6, 2014 12:51 AM
brandyn
Nov 26, 2013 05:31 PM
Levibyz
May 31, 2011 09:43 PM
mamtsberg
Mar 17, 2010 09:15 PM
ryan ortego
May 19, 2005 06:06 PM
