I need imediate help please
Old Jun 9, 2008 | 10:55 PM
  #31
Default RE: Injectors arent closing? Help me
Yes, I saw that post. Something is really screwed up electrically. Let me look at some of my wiring diagrams and post back in a bit.
Old Jun 9, 2008 | 11:27 PM
  #32
Wire from injector to ECU (NOT the red/black one) is shorted to ground. Or that circuit in the ECU is fried.
Old Jun 10, 2008 | 09:16 AM
  #33
HondaPhyco's Avatar
ok so replace ecu? also i did find a stripped yellow and blue wire by the egr value. and does the ecu have to come from the same year and model.
Old Jun 10, 2008 | 09:46 AM
  #34
No, look for short-to-ground before getting a new ECU. If the real problem is a short in the wiring harness, a new ECU won't fix it. TEST stuff, to figure out what's wrong.
Unplug harnesses from ECU.
Unplug each injector & measure continuity from non-red/black wire to ground. (Yes, you'll need a meter)
Old Jun 10, 2008 | 07:59 PM
  #35
HondaPhyco's Avatar
Default RE: I need imediate help please
ok jim...i bought the meter. i measured the voltage and got 25 all across. ok this meter has a setting that when current flows it makes a steady noise. ok well i did test the non black and red side and the sound went away after two seconds meaning the ecu is fine? it was the same forall four injector wires. as for the other side on voltage at on position but after key went off the metershowed climbing voltage untill steady. anything seemed wrong here. and will a short make the fuel pump run that long? according to PaHonda it could be the ecu or the relay. so give me your opinion or more things to test. thank you.
Old Jun 10, 2008 | 11:01 PM
  #36
OK I'm not real sure what you tested.
1 - Unplug allthe wiring harnesses from the ECU
2 - Set the meter so it beeps when you touch the leads together
3 - Touch one lead tothe non-red/black wire at injector, touch other lead to a good ground
Thenthe metershould NOTbeep because that wire isn't supposed to be hooked up to ANYTHING.
Old Jun 11, 2008 | 06:49 AM
  #37
HondaPhyco's Avatar
ok unplugged everything from ecu no voltage on the non red and blak side and 12 volts on the other side. but it didnt beep. but meter shows voltage. what else?
Old Jun 11, 2008 | 07:33 AM
  #38
From your earlier post, I really don't get the voltage climbing up to 25...?? That's bizzare so I suspect you had the meter set for something other than DC Volts.
Old Jun 11, 2008 | 08:56 AM
  #39
HondaPhyco's Avatar
well the voltage on the black and red side is 25 volts like pa said it should be. ok so if everything is fine now what do i do?
Old Jun 11, 2008 | 02:25 PM
  #40
It should read 12V on the red/blk wire, not 25V.
We do not want you to check for voltage on the non-red/blk wire (what color are those wires anyway?). You want to check for continuity on the non red/blk wire.
Tell me what brand of volt meter you got, and I will look up the symbol that you need to switch your volt meter to.
