I need imediate help please
Old Jun 12, 2008 | 11:17 PM
  #51
Default RE: I need imediate help please
You do not need to replace the fuel pump. It is getting power and delivering fuel pressure. The dealership is wrong.
Old Jun 12, 2008 | 11:20 PM
  #52
HondaPhyco's Avatar
But why is it running constantly? thats all i need to know, do you know how it feels to see your baby sit there like a log? lol
Old Jun 12, 2008 | 11:33 PM
  #53
I think that it could be your main fuel relay shorting out. Just looked at the wiring diagrams.
Do the same continiuty test on the non red/blk wire. Just unplug the main fuel relay and keep the ECU unplugged.
Old Jun 12, 2008 | 11:36 PM
  #54
I am having trouble replying to your post.
Old Jun 12, 2008 | 11:39 PM
  #55
HondaPhyco's Avatar
that would be a cheaper fix, ok I tested all the wires you told me to test, i forgot which side i tested but what ever side is suppose to have 11.9 or 11.7 volts i tested, also i tested the other side and got 0. so closed circuit as you said right?
Old Jun 12, 2008 | 11:45 PM
  #56
That is right. I wanted to make sure that you had all of the connectors to the ECU unplugged when you did this.
Old Jun 12, 2008 | 11:50 PM
  #57
Replying to this post is getting frustrating. Sometimes my replies work, sometimese they won't go through.
Old Jun 12, 2008 | 11:52 PM
  #58
Post 49 you say the other side has closed circuit? Closed towhat? Under what conditions? It's NOT supposed to be a closed circuit. Maybe that's the problem?
That wire is only supposed to be closed to ground during the brief moment when the injector is actually firing. Not ALL THE TIME.
Old Jun 12, 2008 | 11:56 PM
  #59
Jim,
You are correct. That side should not be shorted to ground. I meant that HondaPsycho was correct in that a 0 reading was a closed circuit.
I was looking at the wiring diagrams for the MFR. The injector ground wire controlled by the the ECU is also used by the MFR to pin A23 of the ECU.
If the MFR has a short from the A23 to the A7 (pins 1 and 3), then this could explain both problems.
Old Jun 12, 2008 | 11:58 PM
  #60
HondaPhyco's Avatar
Ok the ECU is unplugged, the fuel pump is unplugged and the key is in the II position.
