i need a picture of an idle control soleniod on my 87 accord
my car starts and runs fine till it warms up. then the revs go down to about 300 and then it dies. ive changed the fuel filters and checked the vaccuum lines for leaks and looked at the carb a little and everything seems good but im not good enough with cars to rebuild the whole carb. anyway, i think what i need to check next is the idle control solenoid but i dont know where it is. i need a picture of it.
87 accord LX 5 speed
thank you. im kinda stumped. everything i do to this car makes it run better for one day and then it goes back to doing the same thing. dying at an idle. it runs fine till it gets nice and warmed up, then if u let the revs come down all the way itll die. ive replaced the plugs, wires, cap and rotor, flushed the horrible disqusting oil out, replaced the bad valve cover gasket, both fuel filters, ran seafoam in the gas and sprayed the crap out of the carb with cleaner. oh and i got a new choke sensor or choke thermostat or something cause it was bad. everything seems to help but it always ends up dying at stop signs.
eddy_764
Dec 23, 2010 12:55 AM
