I think I goofed up with hose Routing
Old Feb 9, 2015 | 08:08 AM
drummer1279's Avatar
Default I think I goofed up with hose Routing
the antifreeze hose running into my FITV burst the other day, so of course, when one goes the others are not far behind. Bought new hose and replaced them all, but I think I may have mis routed the 2 small ones coming out of the T-stat housing going into the valve, and the throttle body respectively, because now I have the telltale honda idle surge when it warms up. So does it go top hose to FITV and bottom hose to throttle body? or vice versa?
Old Feb 9, 2015 | 11:13 AM
Refer to attached cooling hose parts diagram for routing.
Old Feb 9, 2015 | 11:32 AM
thats exactly what I needed. thank you sir.
Old Feb 9, 2015 | 11:36 AM
No problem. If the hose routing is correct, then it may be air in the cooling system that needs to be purged.
Good luck.
Old Feb 9, 2015 | 01:33 PM
I seriously think I crossed the routing. after looking at the diagram.
Old Feb 10, 2015 | 03:15 PM
Not the problem. hoses were routed correctly. i had an older IACV that I swapped out to see if that solved the issue, nope. it will idle fine until it comes up to temperature, then it starts surging from 900-2000k Rpm back and forth.
Old Feb 10, 2015 | 04:23 PM
Search for a how-to thread about tightening the plunger inside the FITV. I haven't actually done that myself so it's better for you to find that thread.
Old Feb 10, 2015 | 04:49 PM
its tightened all the way down. it will idle fine in gear, slightly high, but when its in park or neutral, its surging.
Old Feb 10, 2015 | 05:27 PM
1. Did you try to purge air out of the cooling system yet?
2. These attached images are instructions for diagnosing an idle fluctuation on 90-93 Accords, from a February 1999 Honda Service News.
Attached Thumbnails I think I goofed up with hose Routing-diagnosing-idle-fluctation-90-93-accord.jpg   I think I goofed up with hose Routing-diagnosing-idle-fluctation-90-93-accord-continued.jpg
Old Feb 10, 2015 | 06:03 PM
I did, yes. all the air is purged out of the cooling system.
