I think I made a mistake....
Old Sep 16, 2008 | 10:30 PM
bigdawg74's Avatar
Default I think I made a mistake....
Howdy, everyone! Newbie here with my first post. Recently bought a 90 Accord LX w/ auto tranny and about 236K on it. Ran fine for awhile, then started to idle rough when stopped at a light or letting off the gas. A co-worker thought I had some moisture in the gas, so I bought a bottle of HEET. Also bought a bottle of fuel system cleaner (thought it couldn't hurt). Filled up the tank and dumped both bottles in. Well, now it barely starts when it does after an occasional backfire, I have to keep the RPMs up around 2000 or so. When you let off the throttle, or go to put it in gear, it sputters and dies. I am guessing that it doesn't like the FS cleaner/HEET cocktail I gave it. Do I have to siphon the whole tank out? Or is there something else I am missing? Not knowing the previous maintenance history, I was planning on changing the distributor cap & rotor/spark plugs/pcv valve soon, along with changing the oil. Anything else I should be looking at? I just want to get this thing running again. Thanks for your help.
John
Old Sep 16, 2008 | 11:35 PM
Default RE: I think I made a mistake....
They probably both contain some methanol to dry the gasoline (take a look at the active ingredients in each bottle).
I think that it is a good idea to change the routine maintenance items, so you can eliminate them as the problem. You might want to change out the fuel filter (read writeup on page 4 in the DIY section).
Old Sep 17, 2008 | 09:00 AM
falkore24's Avatar
x2 .... I was thinking a clogged fuel filter as I was reading this as well.
It sounds like this car could be a candidate for IM and TB removal for bench cleaning as well. Then and only then I'd run seafoam too. Marvel mystery oil to clean out the crankcase for 1000 miles, a new air filter ....
Old Sep 17, 2008 | 09:18 AM
08coupex's Avatar
Im also saying the fuel filter, I would do the fuel filter first and if that fixes your problem the tune up will just add to better performance and fuel economy.
Old Oct 13, 2008 | 07:43 AM
bigdawg74's Avatar
Ok, I changed the plugs, plug wires, dist cap & rotor, pcv valve, fuel filter, and gave it a new battery. Started it up last night and it sounded great. Idled at about 750-800 RPM. BUT, as soon as I put it in either reverse or drive it stalled. Now it doesn't want to start. Any ideas?
Old Oct 15, 2008 | 10:53 AM
f allen's Avatar
main fuel relay under dash is a problem for these yrs, change it with a new one from honda
Frank Allen
davidg99
Apr 14, 2011 01:58 AM
Acc96ord 2nR
Apr 5, 2010 11:08 AM
986ci's
Apr 1, 2009 06:24 AM
apaksl
Feb 2, 2008 08:37 AM
YeuEmMaiMai
Aug 3, 2006 03:02 AM
