I used anti-seize on my 2003 accord coupe, am I ok?
Old Nov 19, 2012 | 10:21 AM
cryomerlin's Avatar
Default I used anti-seize on my 2003 accord coupe, am I ok?
I've been reading through the forums and the debate about whether or not to use anti-seize on the NGK Iridiums. Seems NGK put out a bulletin not to use it because it can distort torque values. I read these after I installed my new plugs on my 4 cylinder accord. I used the anti-seize, then torqued them in to honda spec 13 ft/lbs of torque. If the anti seize made me overtorque them, how much latitude do I have before I do damage to the threads? Do you think I'm ok to leave them in, or do I need to back them out and reinstall with less torque? I've heard 30% reduction in torque when anti seize applied. Please help! Car runs great, no issues there. Just concerned about potential future damage if I did something wrong.
Old Nov 19, 2012 | 10:46 AM
I think you're OK. I've used antisieze on sparkplugs for a long time.
Old Nov 19, 2012 | 02:59 PM
cryomerlin's Avatar
Thanks Jim, that's a great comfort.
Old Nov 19, 2012 | 09:24 PM
I use it on all of mine as well.....just don't over do it and life it good IMO.
Old Nov 20, 2012 | 09:46 AM
It's more likely to break the threads if you goop it up with antiseize & then TIGHTEN! it without a torque wrench.
Old Nov 23, 2012 | 08:46 PM
FastLane's Avatar
I have used ASC for years.
I still do it old school, hand tight then 1/4 turn. Never had an issue.
The only caveat I know of is to only install plugs in a cold engine, as the torque of a steel plug on a hot head can strip the threads on the aluminum head. HTH.
Old Nov 24, 2012 | 01:54 AM
holmesnmanny's Avatar
Never used anti-seize and still never had a problem.
Old Nov 24, 2012 | 04:40 AM
UhOh's Avatar
Originally Posted by cryomerlin
... NGK Iridiums.
I used the anti-seize, then torqued them in to honda spec ...
Seems like you're good-to-go for the next 150,000 miles.
Don't see any issue in the meantime from my perspective.
dman
Feb 26, 2012 01:37 AM
abhijitgp
Sep 7, 2011 10:07 AM
stiege
Mar 22, 2011 12:02 AM
honda2K
Mar 21, 2010 12:05 AM
Accord91Pearl
Aug 14, 2008 06:56 PM
