I used anti-seize on my 2003 accord coupe, am I ok?
I've been reading through the forums and the debate about whether or not to use anti-seize on the NGK Iridiums. Seems NGK put out a bulletin not to use it because it can distort torque values. I read these after I installed my new plugs on my 4 cylinder accord. I used the anti-seize, then torqued them in to honda spec 13 ft/lbs of torque. If the anti seize made me overtorque them, how much latitude do I have before I do damage to the threads? Do you think I'm ok to leave them in, or do I need to back them out and reinstall with less torque? I've heard 30% reduction in torque when anti seize applied. Please help! Car runs great, no issues there. Just concerned about potential future damage if I did something wrong.
I have used ASC for years.
I still do it old school, hand tight then 1/4 turn. Never had an issue.
The only caveat I know of is to only install plugs in a cold engine, as the torque of a steel plug on a hot head can strip the threads on the aluminum head. HTH.
Don't see any issue in the meantime from my perspective.
dman
Feb 26, 2012 01:37 AM
stiege
Mar 22, 2011 12:02 AM
