idle
Old Mar 13, 2012 | 08:00 AM
drummer1279's Avatar
Default idle
so I guess bad things happen in 3's even on cars. I took my car in to have the lower rocker seals replaced, and a valve adjustment, because I don't have the tools to do those myself. i get the car back and its running fine, I change the oil and then drive it 160 miles down the highway. When I get off the highway and into stop & go traffic the engine starts chugging at idle, the best description I can give is a slow choppy idle like what you would hear on a harley bike. but when I step back on the gas to go, it runs great, no sign of the chug. I have changed fuel filter, PCV valve, no exhaust leaks, plugs/wires/cap are new-ish, and my air filter is new. what else could this be? because Im about to take it back to the mechanic and make him put my valves back where they were.
Old Mar 13, 2012 | 03:37 PM
UhOh's Avatar
I would take it back to the mechanic, describe the problem and let him solve it under his work warranty.
Old Mar 13, 2012 | 03:46 PM
I did, he says there is nothing wrong, that I have an exhaust leak somewhere
Old Mar 14, 2012 | 07:40 AM
better description, it sounds like it has a bad vaccuum hose somewhere, since it only idles rough
Old Mar 14, 2012 | 06:06 PM
Check the PCV seal and hose....if loose you can get a "looping" idle. If they had the VC off, possible that something happened to it.
Old Mar 15, 2012 | 08:59 AM
re checked the PCV and hose, both are good, the grommet is still soft and pliable. I found a vacuum diagram in my Chilton manual and went through all the lines, so I know for a fact i don't have any vacuum leaks now.
Kpick
May 5, 2015 08:51 PM
HatchJunki
Mar 9, 2013 08:23 AM
90pioneer
Apr 9, 2012 09:06 PM
RWilliams
Jul 24, 2011 09:16 PM
fperezal
Jun 14, 2006 05:03 AM
