idle hunt
Old Oct 27, 2008 | 08:55 PM
petercampusa
Default idle hunt
i have a 1991 accord lx and when in park or neutral the idle goes up and down but in drive or reverse it doesnt. anyone had this problem?
Old Oct 27, 2008 | 09:53 PM
finch13's Avatar
Default RE: idle hunt
It could be you're Idle Air Control Valve on the backside of the intake manifold being gunked up with carbon and not opening. This is what allows air into the cylinders when the throttle plate is closed (foot off the pedal)
Old Oct 28, 2008 | 12:35 PM
klrspz's Avatar
Or a PVC Valve... which is really cheap and easy to fix.
Old Oct 28, 2008 | 12:41 PM
finch13's Avatar
ORIGINAL: klrspz
Or a PCV Valve... which is really cheap and easy to fix.
Fixed it for ya ;-). Try PCV first, they're like $4 max. I personally would get a NAPA one, all others I've gotten tend to break apart.
Old Oct 28, 2008 | 03:32 PM
cjdm98's Avatar
On my old Integra, i had the same problem, I cleaned the IACV with Carb cleaner, and it worked fine after that, tweeked the distributor a bit to get the perfect idle.
90pioneer
Apr 9, 2012 09:06 PM
RWilliams
Jul 24, 2011 09:16 PM
donniejr81
Dec 26, 2010 10:26 PM
petercampusa
Oct 28, 2008 08:54 PM
fperezal
Jun 14, 2006 05:03 AM
