Ignition switch sticking
Old Sep 4, 2008 | 06:21 AM
SteveZ's Avatar
Default Ignition switch sticking
I have a 92 accord. The ignition switch sticks sometimes. I wiggle the steering wheel and it doesn't appear to help. It seems to be getting worse. I'm thinking the ignition switch needs to be replaced at a price of over $200 just for the part. Any suggestions?
Old Sep 4, 2008 | 12:31 PM
Default RE: Ignition switch sticking
The ignition switch can be locked by steering column, but also by the interlock system which prevents the transmission from being shifted unless the brake is pressed. Have you checked whether you can shift the trans when this happens? If brake switch is the problem, sometimes WD40 sprayed on the switch will restore it.
If it's the key itself causing the problem, I would first have a new key cut by Honda. They may have to look up your code. Worn key can cause sticking. A little wd40 may help the keywitch work better. You want to use a very light oil like WD40, but there are many light spray oils that will work.
Old Sep 4, 2008 | 01:18 PM
SteveZ's Avatar
I forgot to post. It's a 5 speed standard transmission. I do have the key code so maybe I'll try to get a new key cut. Thanks !
Old Sep 5, 2008 | 11:41 AM
jcocker03's Avatar
same problem with my car-92 accord lx coupe 5 spd.
Wiggling the steering wheel and key seems to help, post it if the new key helps, with 217K on my car my key could be worn too
Old Sep 6, 2008 | 09:57 AM
SteveZ's Avatar
Had new key made yesterday at honda dealer. The guy made three keys one works but it won't open trunk. I have been using my valet key without any problems so I think the key is the issue. I think I'll go to another dealer and have another key punched. The guy gave me all three keys no charge but I'd rather pay and have one work. I'll let you know when I go to another dealer and see how they do.
Matthew Kniss
Jun 30, 2014 06:00 PM
shehadehd
Sep 20, 2012 05:20 PM
ccnicco48
Jan 16, 2008 05:16 AM
illfaver
Aug 30, 2007 03:02 PM
Fergy
Jun 22, 2006 03:41 AM
