Ignition Wiring
Old Nov 25, 2012 | 06:34 PM
KelvinR's Avatar
Default Ignition Wiring
Car is a 1995 Honda accord auto
Hey guys, someone tried to steal my car last night and messed up my ignition lock so I cant start my car with my key. So I went online and am trying to use a switch and a push start to turn it on in the meantime I get paid.
So I basically hooked up the White 12v+ to the blk/ylw and yellow cables which turns on everything in the car.
Then I put the blk/wht cable with the white cable with a push start which turns the car on.
So far so good but im left with a white/ blk cable which is for the radio. So I thought i had to hook that one up to the switch as well. So I did and the radio turned on. But one problem my steering wheel locked up and When I switch gears from P to D it makes a clicking noise so I know I messed up somewhere.
Any help will be appreciated thanks!
Old Nov 26, 2012 | 07:20 PM
The "lock" of the steer wheel is with the key part of the switch....which might be bad depending on what they messed up.....so we might not be able to get around that until you drill out/remove the key switch from the column.
Maria Penguini
Jul 15, 2014 10:39 PM
shehadehd
Sep 20, 2012 05:20 PM
Redcap
May 7, 2008 05:29 PM
qbantaz
Dec 9, 2007 12:04 PM
ryan ortego
May 19, 2005 06:06 PM
