1994 Accord Ex 2.2 Vtec Ignition Module Wiring Issue
Old Jul 14, 2014 | 09:48 PM
Maria Penguini's Avatar
Default 1994 Accord Ex 2.2 Vtec Ignition Module Wiring Issue
I replaced the Ignition Module inside the distributor and made the error of not photographing the wiring like I usually do prior to disassembling. Now I am not sure which wires go where.
The Ignition Module (igniter)(ICM?) - so confused on this terminology
is not like alot I see while searching, It says E12-127 on it and was part number 30120-POA-A01
there are two wires with insulators over the clips and 2 with,
one wire goes to the coil (which I also replaced)
the attached pic has the wires pulled out on top so i could photo them, normally they are below attached to the module
just need to know which order they go in, left to right....
Attached Thumbnails 1994 Accord Ex 2.2 Vtec Ignition Module Wiring Issue-honda.jpg
Old Jul 14, 2014 | 10:08 PM
See attached image.
Attached Thumbnails 1994 Accord Ex 2.2 Vtec Ignition Module Wiring Issue-icm.jpg
Old Jul 15, 2014 | 10:39 PM
Thank You!!!
cd51994accord
Jan 30, 2014 12:56 PM
93Accord2.2
Sep 2, 2013 08:07 AM
charlieadams
Sep 18, 2012 07:11 PM
RockAuto
Apr 20, 2012 11:10 PM
