I think vibration in these new axles caused my ignition module to fail
Old Sep 2, 2013 | 06:34 AM
93Accord2.2's Avatar
Default I think vibration in these new axles caused my ignition module to fail
I opened it up and one of the TINY little wires is broken.. Not sure if it is fixable because everything is covered in some clear slimy stuff (not sure if that is necessary for cooling or WHAT- but once you touch it, it's never the same again)
But it is pretty funny that the module failed, what, a week or so after these axles went in?
Well, yall were right about cheap axles. Sigh. One good thing (I guess) is that I have not been skipping third any more. The vibration is worst right before a shift point, so I have been driving easier and shifting more.
Is there ANYTHING I can do to cure the vibration without changing them again? I KNEW getting cheap ones would cost more in the long run.. but had no idea it'd be in the short run, here
What else is likely to fail due to the vibration????
And why are the "wires" so extremely tiny inside of the ignition module? I've never seen anything like that before.. that seems pretty damned stupid to me!!
Old Sep 2, 2013 | 08:02 AM
I'm not aware of anything you can do to fix an axle that vibrates. I suspect (but don't know) that the rubber rings on the axles may suppress vibration. OEM and Raxles have them (AZ, ORiellys, etc don't). Only short term solution is what you're doing, take it easy.
Wires are tiny because they carry very small currents and there is limited space. These wires and insulation get brittle w/ age, heat, and oil. Usually shaft seals leak on older distributors leading to motor oil inside distributor. Make sure the drain opening is draining or oil will overwhelm and short distributor.
Old Sep 2, 2013 | 08:07 AM
I guess I was lucky because there wasn't any oil in the distributor at all.. I've read that these are prone to that, so I was not looking forward to looking under there
I know they don't have alot of room in there, but wow, it's just dead space and TINY TINY wires .. you would not believe how small they are. . 2x a human hair, maybe?
RockAuto
Apr 20, 2012 11:10 PM
VelvitJones
Mar 23, 2012 07:01 PM
EBK142
Jul 20, 2009 09:10 AM
HondaPhyco
Apr 1, 2008 07:23 PM
