Installation of ES control arm bushings
Old May 17, 2011 | 06:38 PM
Tek310's Avatar
Default Installation of ES control arm bushings
So I see you need a press to get the original ones out. Thought it would be easy by the bushings I got in.
I'm replacing my whole front steering/suspension minus springs and shocks
(upper/lower control arms, inner/outer tierods, upper/lower balljoints, and swaybar endlinks)
Replacing OEM bushings with energy suspension poly bushings.
Now I need a press?
Old May 18, 2011 | 01:43 AM
ronjr8102's Avatar
would make it easier. I hav seen a way where u melt or drill out the rubber, sawzall (dont know how to spell it) one side of metal sleeve (dont cut into part) then use ball-joint press/c clamp w/ socket to press out old sleeve then use it again to press in.
JohnNH
Jan 1, 2015 03:32 PM
Tony1M
Jul 7, 2011 04:32 PM
hutchisonz
Dec 30, 2010 01:33 PM
manu_b
Aug 26, 2008 09:29 PM
oma93
Feb 13, 2008 09:19 PM
