installing an aftermarket temp gauge
Old Jun 12, 2006 | 03:33 PM
sportsman1539's Avatar
Default installing an aftermarket temp gauge
i have an aftermarket temp gauge on my car right now but i dont know how to hook it up. the guy that had the car before attempted to hook it up but its just not working. how do you hook it up? i was guessing somewhere around the thermostat but i really dont know. thanks
Old Jun 12, 2006 | 06:09 PM
sir_nasty's Avatar
Default RE: installing an aftermarket temp gauge
there should be a temp sensor right around the thermostat (I believe it's towards the back of the car from the thermostat) it's usually only two wire. what year/model do you have?
Old Jun 12, 2006 | 06:17 PM
its a 94 lx. it looks like he has it wired up to the sensor thing that hooks into the thermostat. i think its hooked up wrong.
Old Jun 12, 2006 | 06:22 PM
sir_nasty's Avatar
is it either backwards by chance? check with a voltage meter and make sure it's even giving off a reading....
Old Jun 13, 2006 | 01:17 PM
fperezal's Avatar
Electrical or thermal? If is thermal, go to the top hose where it goes to the engine. Go to this link temp_gauge and you will see a drawing I made for you. I done this 4 times with no leaks at all. When bending the probe into the water outlet/hose pipe, cut a little of the spring (dont cut the copper; be very careful) and insert only the thin copper line. Be careful when bending this. Let me know if you like my idea.
pirulino23
Nov 10, 2010 06:18 PM
raf105
Sep 28, 2007 02:55 PM
corr04
Jun 7, 2006 01:24 AM
honker3
Dec 6, 2005 08:33 PM
fperezal
Sep 29, 2005 09:29 PM
