intake manifold advice
Old Jan 8, 2011 | 02:38 PM
reut1's Avatar
Default intake manifold advice
so I need to pull the intake manifold off my mothers 01 accord LX to clean it up since im still getting insufficient EGR flow after replacing the valve so i assume there is plenty of carbon build up since the cars got 160k on it.
is pulling the manifold mostly straight forward and will all I need to buy before hand some cleaners and a new gasket or is there anything else I need to get myself besides that gasket?
Old Jan 8, 2011 | 04:54 PM
Is this a 4 or 6 cylinder?
Some throttle body cleaner and a test tube brush.
I would get the intake gasket and the throttle body gasket.
Old Jan 8, 2011 | 07:48 PM
reut1's Avatar
4 cylinder. okay so those two gaskets ill pick up before i start the job. and pulling the manifold is mostly straight forward?
Old Jan 8, 2011 | 10:46 PM
It is pretty straightforward. You will have to remove the throttle body. There are some coolant lines that go to it, so it may be a good time to drain and replace the coolant.
I think that you will have to remove the upper half of the intake manifold first to give you room to remove the lower half. Then remove the lower half. Mark all vacuum tubes/connectors, etc, so you have an easier time putting it all back together.
You probably should get that gasket between the upper and lower intake manifold.
fopokev07
May 23, 2008 10:18 PM
JerseyTuscani
Jul 2, 2007 05:21 PM
jipmpizzle
Aug 1, 2006 01:18 AM
guitargod33
Mar 27, 2006 11:22 PM
zelseman
Dec 13, 2005 11:51 AM
