interior dome light
Old Nov 29, 2007 | 11:21 AM
94Honda's Avatar
Default interior dome light
when i corner real hard to the left or if any weight is on the passenger side door the dome light comes on. anyone know how to fix or why its doing it?
Old Nov 29, 2007 | 11:37 AM
00AccordLX5spd's Avatar
Registered User
Default RE: interior dome light
Haha...a quick way would be to switch it to the "off" position (the position where the light won't come on when you opena door.)
It sounds like something is amiss with the sensor in the passenger side door though.
Old Nov 29, 2007 | 11:42 AM
There's a button switch in the doorjamb, I think it's near the bottom of the B-pillar. Check whether it's loose, maybe you just have to tighten the mounting bolts?
Otherwise, check the part of the door that hits the switch. Bent? Corroded? Anything that would cause it to NOT press that button all the way in?
Old Nov 29, 2007 | 11:47 AM
deserthonda's Avatar
the door striker might need to be adjusted inward a bit more, loosen the 2 philip screws at the door striker, push the striker a bit inward , tighten the screws and see if that helps ..
Old Nov 29, 2007 | 01:29 PM
94Honda's Avatar
Sweet thnx ill try
Old Nov 29, 2007 | 08:17 PM
94Honda's Avatar
heck yeah i adjusted the striker and the door opens and shuts soooo much better now and i tested the light situation and its golden. so all the doors are adjusted and its mint. thnx
bdrumm
Oct 30, 2012 10:46 AM
N1Accord
Mar 24, 2011 11:27 AM
glen e
Dec 22, 2008 01:05 PM
eckhart
May 8, 2006 01:05 PM
