Intermittent No start issue
Old Jun 2, 2018 | 04:17 PM
muddog728's Avatar
Default Intermittent No start issue
I have a 95 accord LX. When it's hot outside or when it has/is raining, it takes awhile for the car to start. When this happens, I will turn the car on the CEL will stay on. The fuel pump doesn't turn on. The car will crank, but not fire. After a few minutes of waiting or cycling the key on/off. I will hear the EGR valve lift, my fuel pump will turn on and the CEL will turn off and the car starts find and runs fine. I have replaced the main relay. I have checked the ground on the manifold, the fuel pumo ground, the driver side engine mount ground and the battery ground. I have aslo inspected the ECU and TCU for burnt spots and leaky capacitors. I'm looking for anyone that has any idea what the issue is. Thanks.
Old Jun 2, 2018 | 06:15 PM
The CEL and the fuel pump prime are controlled by the ECU. I'd suspect an ECU problem, since you replaced the main relay.
mattcadieux1
May 8, 2013 08:45 PM
SlyBlackDragon
Jan 6, 2012 10:13 PM
stubs
Aug 6, 2010 10:29 AM
jmvar
Dec 11, 2008 03:38 PM
AustinGT
Sep 9, 2008 05:42 PM
