Issue after brake fluid change
Old Jul 28, 2013 | 05:54 PM
  #21
Small bubbles are a consequence of vacuum bleeding and don't cause a problem as they don't get into any permanent fluid in the system. They occure when air enters around the loose bleeder into stream leaving the caliper.
Old Jul 28, 2013 | 06:13 PM
  #22
LS-300's Avatar
Thanks! I was starting to freak out. I haven't done it in a while and don't remember having all the tiny bubbles.
Old Jul 28, 2013 | 07:02 PM
  #23
After a lifetime of pedal pump bleeding I bought a vacuum bleeder from Harbor Freight. I've done 5 vehicles now w/o problems.
Some folks remove the bleeder and pack grease around the bleeder to prevent air bubbles. I suspected there would be no problems w/ allowing bubbles to enter at the bleeder and this has proved to be the case. No problems w/ soft pedal at all.
Old Jul 29, 2013 | 11:05 AM
  #24
I used a vacuum bleeder and get all the tiny bubbles. I tried to pack grease around the base of the bleed screw, without removing the bleed screw. That was a big improvement, but it's difficult to smear the grease around without leaving an opening somewhere.
But then I got a pressure bleeder and I like that a little better yet.
93Accord2.2
Dec 17, 2021 09:59 AM
62maxx
Oct 18, 2015 08:20 AM
logannz
Mar 30, 2013 05:20 AM
93Accord2.2
Jan 20, 2012 01:02 PM
62maxx
Nov 21, 2006 12:04 PM
