Issues with Brake Lights
Old May 3, 2009 | 08:43 PM
Lullapalooza
Default Issues with Brake Lights
I have an 02 Accord Coupe.
Today, the "Brake Lamp" indicator went off on the dashboard, and so I looked into the problem by myself. I put one of my massive biology textbooks on the brake and went to the back of the car to check it out. Sure enough, only one light was lit up.
But then, when I turned the headlights on, something weird happened. You know how when you are driving at night, you turn on the headlights and automatically your tail lights go on. Then when you hit the brake, your tail lights become brighter. For me, the tail light went on, but when hitting the brake, it did not bright up as much as the other one.
So, I'm thinking that it's not the bulb itself, but rather something with the wiring of the car? Is that a fair assessment? How much would something like this cost to fix from my local Honda dealer?
Old May 3, 2009 | 09:03 PM
It might be something as simple at the contacts of the bulb are worn or not seating properly.
It might be worth the $5 to put in two new bulbs.
Old May 3, 2009 | 10:00 PM
Lullapalooza
Thanks for your input. Do you recommend I take it to my dealer, or to a local mechanic? I have a bumper to bumper warantee on the car with a $100 deductible. Even if it is a wiring problem, would it cost more or less than $100?
If I'm spending a lot of money, I'd obviously prefer to take it to my dealer.
Old May 4, 2009 | 08:10 AM
First, replace the bulb. There's 2 separate filaments in those bulbs, so as far as the wiring's concerned, it's like 2 separate bulbs. One filament (taillamps) is OK, but the other (brakelamp) is not.
If it brightens up a little bit (but not enough) still replace the bulb. That 'brake lamp' warning is based on the wattage matching from side-to-side. Occasionally people have to replace all the bulbs just so they match each other.
Old May 4, 2009 | 08:46 AM
njmodi's Avatar
As JimBlake said - the brake lamps are dual filament - the filament that lights up when you press the brakes is broken (on the side you don't see it get brighter).. replace the bulb and you'll be set.
rudeg
Dec 31, 2015 07:23 PM
csh217
Apr 30, 2013 09:03 PM
thebartender2010
Oct 24, 2011 11:51 PM
GOT BOOST
Nov 2, 2009 08:32 AM
drive4fun
Aug 5, 2008 08:28 AM
