TCS Lights & Brake Lights On..
Old Oct 14, 2007 | 08:00 PM
drive4fun
Default TCS Lights & Brake Lights On..
I've searched the forums and found a few threads on the topic. Nothing really answered the issue.
This is what I'm getting on my display.
http://www.v6performance.net/gallery...enHunter_3.jpg
Brake light, and both TCS lights are on.
Brake light always stays. TCS lights come on after about 30 minutes after start up.
I've read that maybe I should replace the brake light switch.
I have a 2003 Accord Ex V6 with 23,000 miles. Brake fluid level is above minimum. I believe it's time to replace the brake fluid in my car (Honda states every 3 years?). I also have to take a look at the brake pads and see how worn out they are.
Could it be possible that the lights are on because of the need to replace the fluid or change the pads? I'm not getting any screeching sounds.
I might head to the dealer tomorrow morning before work to find out. I have extended warranty so that should cover it.
Old Aug 5, 2008 | 08:28 AM
OhThreeVeeSix's Avatar
Default RE: TCS Lights & Brake Lights On..
I have exactly the same problem on my 2003 EXL V6. Did you ever determine what was causing this?
Thanks in advance,
Brad
ramman949
Aug 14, 2012 06:05 PM
OhThreeVeeSix
Sep 25, 2009 02:12 PM
2003 V6
Jul 16, 2008 08:02 AM
drtysohc
Feb 3, 2008 03:23 PM
scott
Oct 8, 2007 05:38 PM
