jump starter solenoid?
Old Apr 8, 2011 | 12:07 AM
westcoasthonda's Avatar
Default jump starter solenoid?
how would i do it,when i try to start the engine theres no cranking or clinking,im thinking maybe the starter,i was reading some where you could try jumping it by connecting a screw driver to something
Old Apr 8, 2011 | 02:38 AM
The small wire to the starter should get 12V when you try to start the car. What year, etc. of accord do you own?
Old Apr 8, 2011 | 06:36 PM
97,4 door,its been sitting for a while
Old Apr 8, 2011 | 06:45 PM
You may need to charge the battery, or jump start the battery.
To turn on the starter without using the key, you need to supply 12V to the post where the smaller blk/wht wire bolts the starter. You can use a jumper cable from the + battery post to the that post.
If the starter contacts are worn out, the jumping method may not work. You can have someone hold the key in the start position inside the car and hit the starter housing with light/medium force with the handle of a screwdriver near the electrical connections. It is the caveman test for the starter.
Old Apr 8, 2011 | 09:30 PM
i did the screw driver test i found online,touch the positive post and the starter prongs together with a screw driver but i only heard a little click it wont turn over
Old Apr 8, 2011 | 10:30 PM
If that is the same click that you heard when you tried to start the car, then the starter contacts inside are worn out. Replacing the two copper contacts and the plunger inside the starter is a pretty simple DIY.
Old Apr 8, 2011 | 11:21 PM
i also noticed that there was a wire not plugged into the starter it was very small it was just on the side,maybe the people who put the alarm on took it off?
Old Apr 9, 2011 | 01:57 AM
What color wire? Are there two wires connected to the starter?
So you had a new alarm installed?
Old Apr 9, 2011 | 02:46 AM
its a small black one,there is one more already plugged in,no not a new alarm,im gonna take the starter out tmrw and get is tested
Old Apr 9, 2011 | 08:25 AM
Might as well take the battery and have it tested at the same time as the starter.
