Jus have a quick question
Old Nov 9, 2008 | 06:34 PM
jamrock's Avatar
Default Jus have a quick question
i jus replaced the head on my 94 accord ex . does any one know how long im suppose to let it break in b4 i get on it or get it into vtec
Old Nov 9, 2008 | 06:35 PM
Default RE: Jus have a quick question
well considering its probably not a new head, i'm guessing you got it used, there really isnt a break in period, and if its a OEM head vtec can kick in as low as 3,000rpms, so yeah.
Old Nov 9, 2008 | 07:43 PM
jamrock's Avatar
so it should be fine as long as everything is together?
Old Nov 9, 2008 | 07:49 PM
yes sir.
Old Nov 10, 2008 | 07:43 AM
falkore24's Avatar
Don't beat on it for 500 miles if it's really new or recently rebuilt. If it's used and just getting swapped on, no break in is necessary, but you should take it easy just to make sure that there are no problems from the install.
Old Nov 11, 2008 | 10:42 AM
cachecrk
Treat it like it is a new one and you won't be sorry. No towing, high speeds and stay out of cruise control. Vary your speed, gears and listen to your rpms. Change your oil (5/30) at the recommended interval. Those were great engines.
Old Nov 11, 2008 | 12:05 PM
falkore24's Avatar
Well .... as for the oil change. I'd say do the first change at 1000 miles, the second at 3000 miles (+2000 from the first) and then go to regular maintenance. I am currently running Marvel Mystery Oil straight from the oil change last weekend. At 2000 miles it's getting flushed then changed to Amsoil with a filter relocation with a partial flow micro filtration filter in addition to the truck size full flow filter. This is in preparation for a turbo install.
Old Nov 11, 2008 | 03:54 PM
jamrock's Avatar
thanks for all the input
polo_kidd09
May 17, 2011 02:33 PM
rgungher01
Feb 19, 2011 07:39 PM
dunnskii
Jan 14, 2011 09:27 PM
get'er go'in
May 4, 2010 12:33 PM
neal916
Jun 17, 2008 09:33 PM
