Just bought 97 accord
Old Jul 29, 2006 | 07:52 PM
willbjew
Default Just bought 97 accord
I just bought a 97 honda accord special edition.. and the only reason i really bought it was for gas milage and i am kinda disspointed. It has 115,000 miles on it.. First off i am fixing to replace the plugs and change the oil and i will find the timeing belt assembly kit and have a mechanic do that.beacuse i keep hearing to replace that before it breaks. Hopefully the air filter and plugs will help the gas milage... I put a full tank in and drove 275 and have a little less than a quarter of a tank left.. does this sound right... its a 17.04 gallon tank so do the math and it isnt much better than my wrangler. i paid 4 grand out the door for it and it is in good aesthesic shape... what else could i do... it the engine just getting sluggish.... HElP
Will..
Old Jul 29, 2006 | 11:11 PM
mbo1985's Avatar
Default RE: Just bought 97 accord
Any check engine lights??
Plugs are a good place to start. You may even want to run some injector cleaner through the motor or even sea foam it. If you want more power, you have a ton of options. You can redo the exhuast system and/or go for an aftermarket intake system and you could squeeze out an extra 10 or so horsepower. Also check tire pressure and see if any of the wheels are dragging.
You should be getting a little more milage out of it. Do you happen to mash the pedal a lot?
Old Jul 29, 2006 | 11:42 PM
willbjew
no i am real easy on it.... i dont want more power at all... just gas milage....only gas milage..lol
Old Jul 30, 2006 | 01:29 AM
Jm's Avatar
Jm
I have a 97 Ex Auto I think its the same motor thats in your car unless its the v6. If i fill mine i get at least 300 to the tank. And im not always so easy with her
Old Jul 30, 2006 | 06:28 PM
willbjew
ok it has a new air filter and new plugs..... and i am fixing to fill it up again.....Shouldnt it get alot better than this...Please respond....
HELP
Will
Old Aug 7, 2006 | 06:06 PM
evilundoer
I've got a 97 with I believe the same engine, 2.2 4cyl. I get 450 miles per tank full, about 30mpg. I've got 430,000 miles on it.
Dan
bludevil_x
Jun 29, 2006 07:48 PM
reaXion
Mar 31, 2006 01:06 PM
new_oldHondaOwner
Mar 26, 2006 01:56 AM
MassAccord
Mar 11, 2006 06:03 PM
Pat61
Nov 5, 2005 03:04 AM
