Just bought 99 v6 coupe and car cuts off in traffic, Help...
Old Dec 17, 2007 | 11:06 PM
bobs99coupe
Default Just bought 99 v6 coupe and car cuts off in traffic, Help...
Hey, im new here, just bought a 99 coupe v6 EXand it runs great but enginecuts off spontaneously during low rpm driving, and usually cranks back after a few trys. Seller says the car was sitting a while. has about 140,000 miles, and i got a deal for only $3,000. I willchange oil,air filter, and spark plugs tomorrow. The car had a remote start installed and it does not come with the remote, so im thinking this could be the problem with it cutting off (bad wiring, maybe), i don't know.No dask lights areon except the maint req light. Any othersuggestions guys, thanks.
Old Dec 17, 2007 | 11:23 PM
ckebottle's Avatar
Default RE: Just bought 99 v6 coupe and car cuts off in traffic, Help...
Wow! 3000? Really good deal or maybe there is a reason it was only 3,000. Welcome to the forum!
Old Dec 17, 2007 | 11:45 PM
See if you can duplicate the problem by wiggling the key. I don't know why that would only happen when driving slow, but flaky ignition switches are not too rare.
Heavy keychain?
Check with a dealer about a recall campaign for the ignition switch. With your VIN any dealer should be able to tell you whether it applies to your car, & whether it's already been done.
Old Dec 17, 2007 | 11:49 PM
bobs99coupe
Yeah, guess im lucky, the car runs a drives great, extremely quiet (hard to tell if it is still running). No accidents, jus that the previous owner lowered the car 2" off the ground by heating the springs now i have to find more stock springs for it. Any suggestings on the cutting off situation though, i own an Acura legend also that cut off on me and would not crank back and i thought it was the fuel pump but was the main fuel pump relay. I know nothing abouth the 6 gen accords. Please help
Old Dec 17, 2007 | 11:54 PM
The system with the main fuel relay is just like your Acura. Butthat usually(?) won't stall you once the engine is running. Bad main relays normally just prevent starting when the interior of the car is really hot.
Old Dec 18, 2007 | 07:03 AM
YeuEmMaiMai's Avatar
ignition switch recall been done?
Old Dec 18, 2007 | 10:56 AM
bobs99coupe
Yes, called dealer and they said ignition recall was done already.
Old Dec 18, 2007 | 11:23 AM
klrspz's Avatar
Just FYI, there's a few other people posting this problem recently, might be good to do a little bit of searching in the meantime.
Old Dec 18, 2007 | 12:50 PM
sir_nasty's Avatar
when it stalls/cuts out does it sputter like it all of the sudden lost fuel or does it just turn off and coast like the spark got cut?
Old Dec 18, 2007 | 07:10 PM
HondatechAV6's Avatar
most likely it's the ign. switch again. i've done repeat electrical portion of the ign. switch on recall cars several times.
