Key-less Entry Problem
Old Oct 28, 2017 | 08:57 PM
rasslia's Avatar
Default Key-less Entry Problem
Hi all,
My key-less entry to my 2006 Honda Accord is working sporadically, any ideas what could be causing that?
I click the unlock button on the key and the doors do not unlock. Wait about 10 seconds, start clicking again and the doors do unlock. I know it is not the key as I replaced the battery and can tell the key is sending a signal, also tried my other key with the same result.
Thanks in advance.
Old Oct 28, 2017 | 11:17 PM
Possibly a problem with the driver's master switch. The receiver antenna for the keyless system is located in the power window master switch (door multiplex control unit).
Old Oct 29, 2017 | 08:14 AM
rasslia's Avatar
Thank you redbull,
Would you suggest I replace the driver's master switch? Or the multiplex control unit?
Old Oct 29, 2017 | 01:47 PM
The driver's door multiplex control unit is part of the driver's master switch.
csh217
Jun 17, 2014 05:53 PM
Andrew Mox
Jan 3, 2010 10:25 PM
aduffy32
Mar 8, 2009 04:30 PM
cypres
Dec 2, 2008 06:31 AM
caverspencer
Nov 24, 2006 12:00 AM
