key stuck in ignoition
Old May 8, 2012 | 10:37 PM
Raquel1992's Avatar
Default key stuck in ignoition
ok so i just bought a used honda accord and im having trouble with the key it gets stuck in the ignition wen i turn off the car i took it to the dealership 4 times they made a new key and said they change the cylinder in the ignition and im still having the same results it gets stuck in the ignition does anyone know wat i can do or any tricks to taking it out
Old May 8, 2012 | 10:43 PM
If it's an automatic, try pushing the shift lever into Park a little more next time the key gets stuck and try to remove the key to see if that makes a difference.
Old May 8, 2012 | 10:44 PM
Raquel1992's Avatar
Default 2006 honda accord. key stuck in the ignition.
has anyone else ever had a problem with getting the key out of the ignition when trying to get out the car?????? i took it back to the dealer ship & they've replaced the ignition & a new key and its still doing it
has anyone else had this problem?????
Old May 8, 2012 | 10:50 PM
Raquel1992's Avatar
yes it is automatic, ok i am going to try that. thats funny because i called the previous owner just a bit ago and he told me something similar to that. thank you (:
Old May 8, 2012 | 10:55 PM
Just saw your other post that it's a 2006 Accord, at first I thought it was a 1992 due to your user name.
https://www.hondaaccordforum.com/for...gnition-47377/
Since yours is a 2006, this other thread here may be a more specific cause of your problem:
https://www.hondaaccordforum.com/for...key-out-45826/
Old May 9, 2012 | 08:49 AM
hondadude's Avatar
You can also try pushing in on the key as you turn it to the off position.
Old May 9, 2012 | 06:12 PM
Auto trans? If the car doesn't "think" it is in park then the key will not "turn off", allowing it to come out of the cyl.
Old May 9, 2012 | 06:18 PM
Hi friend ,
OP had a second thread here, which had replies too.
https://www.hondaaccordforum.com/for...noition-47376/
Old May 9, 2012 | 06:20 PM
I see that now......watch this
Old May 9, 2012 | 06:21 PM
Okay.
