Knock in Front End - Post II - UPDATE!
Old Apr 24, 2007 | 02:46 PM
Pauls95's Avatar
Default Knock in Front End - Post II - UPDATE!
i've read the other knock post, but how do you know if your struts are going bad? mine exhibits the same behavior as the other poster...a harsh grinding/knocking noise when going over bumps or making a turn @ a decent speed.
my car is a 95 accord w/ ~120K btw.
Old Apr 24, 2007 | 06:15 PM
sir_nasty's Avatar
Default RE: Knock in Front End - Post II - Struts?
If it's the struts going bad that's causing the noise usually your car will feel really "squishy" when turning or going over bumps.... also, if they are hydrualic shocks then you can inspect around the outside of them for fluid that's leaking out of them
Old Apr 24, 2007 | 06:37 PM
Tony1M's Avatar
Carefully check each front coil spring for breakage - usually near the the bottom of the spring.
Old Apr 25, 2007 | 02:56 PM
Dshow's Avatar
Pardon me if this has already been brought up... In the Do-It-Yourself section, there is a post called "Squeaks over bumps???" that points you to here -> http://members.troublecodes.net/hondadude/Swaybar_%20bushings.htm and instructs you to grease you sway bar bushings. This fixed my car over the weekend!
Old Apr 25, 2007 | 06:43 PM
Pauls95's Avatar
thanks for the responses...i'll check the bushings & springs this weekend, as i was going to change the oil then.
sounds like it could be a low cost fix!!!
Old Apr 26, 2007 | 12:31 AM
j_man_honda's Avatar
You may have a busted axle boot.
Old May 4, 2007 | 04:54 PM
Pauls95's Avatar
Default RE: Knock in Front End - UPDATE!
it's the passenger sidesway bar link bushings...they're shredded. any kits you recommend? our local honda dealer said it's a good idea to replace ALL the bushings (~$75 for a complete kit). there's a Moog Kit @ Advance Auto (PN# K90195) for $50, but i don't know if they're an apples to apples comparison. just wondering what others have used w/ success???
Old May 4, 2007 | 08:55 PM
sir_nasty's Avatar
If you're going to replace the bushings I'd look into polyeurethane bushing kits.... if they are around the same price as the rubber ones I'd get them instead to "firm up" everything.... Once in a while they may squeek a little bit but otherwise they're a nice addition....
Old May 4, 2007 | 11:11 PM
That link up from HondaDude on the subject was and is a good one.
Old Dec 1, 2007 | 11:18 PM
oma93's Avatar
Hondadude's link is dead, is it available anywhere else?
Dec 11, 2008 05:36 PM
ziggy!talon
Apr 15, 2008 10:31 PM
SaveItK
Sep 2, 2007 04:21 PM
ScottyJ
Apr 25, 2007 12:55 AM
