Lesson Learned: AC Hose Shot :(
Old Jul 2, 2014 | 06:28 PM
cgeromi's Avatar
Default Lesson Learned: AC Hose Shot :(
Well after almost 2 years my high pressure A/C hard line has sprung a hole Worst time of course in the 100+ heat here in the northeast. The root cause was the medal clamp that holds part of the airbox was put on the wrong way and ended up rubbing a hold in the high pressure hard line. I can only blame myself, which is sometimes the worst haha.
With that said, I am having trouble finding the hardline (with the high pressure fill nozzle) online. Can anyone offer suggestion(s) on where I may get this line?
Here's a pic for everyone to learn from.
Attached Thumbnails Lesson Learned:  AC Hose Shot :(-photo1_zps216e9e44.jpg
Old Jul 3, 2014 | 01:46 AM
Old Jul 3, 2014 | 12:18 PM
cgeromi's Avatar
Thanks! I see they are quite pricy! $196 just for the one hose. What a rip off. $200 for a 3 ft. piece of bent aluminium. Crooks.
Old Jul 3, 2014 | 02:15 PM
May not be the official way but there are splice kits you can get? It looks like it is right at a 90 bend - do a search for "dorman 800-692", pretty sure that is a 3/8 line.
EDIT: They have some other fittings that compress to the hard line and then you can use some ac hose. So two fittings and ~ 6 inches of ac hose is another idea.
Pull it and find a welding shop?
Whatever you decide, since the system has to be "opened up", a new drier should be on the list as well.
Old Jul 3, 2014 | 05:21 PM
The low temperature aluminum brazing rods may be another option. See the many youtube videos on how to use these rods; basically clean, heat and touch rod to parent material.
Old Jul 3, 2014 | 08:34 PM
cgeromi's Avatar
Thanks everyone for the input. I am may try to pull the hard lines from a junk yard car that are in good shape. I just picked up new o-rings at Honda today and have a new dryer coming in at Carquest tomorrow. They also suggested installed a new dryer. I am pretty naive when it comes to AC systems. Can anyone explain why because I had a line go bad that I should also replace the dryer?
Old Jul 4, 2014 | 05:55 AM
The drier will absorb moisture. So if the system is "open" for any length of time, it will basically become saturated.
Old Jul 4, 2014 | 12:13 PM
cgeromi's Avatar
Thanks Scott! The evaporator also absorbs moisture?
Old Jul 4, 2014 | 07:38 PM
The drier captures inevitable moisture mixed w/ R134a to prevent formation of harmful acids that can damage the system. Cheap insurance to replace receiver/drier.
You also need a vacuum pump to pull most moisture from system before charging. Perhaps single most important step in charging. It can also provide a final proof of pressure containment integrity if the vacuum level is held for 15-30 mins w/o dropping more than 2-3 inches-hg. If vacuum level drops to zero in that amount of time, you have a leak!
Old Jul 7, 2014 | 09:18 PM
cgeromi's Avatar
I wanted to follow up with everyone and tell everyone how I made out. The verdict is success
However, I know TexasHonda will be upset, I did not vacuum the system I do not have a vacuum pump and my 6 year old dog was diagnosed with a herniated disc and may need 6 grand in surgery. I installed all new o-rings, 2 very good condition junk yard liquid hard lines and a new dryer. It has been 36 hours and the pressure is dead on spec and the system has 22 oz of freon on her. It blows the coldest air I have felt since I built her 2 years ago. I am amazed at this little car. Now I have to figure out how to remove the evaporator in my 84 (w126) 300sd Mercedes-Benz. This I am sure will be a bit more challenging. Thanks everyone for all there input and information. Long live my '94 Accord with 207,500 miles.
