Let's Talk GAS
Old Dec 30, 2007 | 02:57 AM
eric123's Avatar
Default RE: Let's Talk GAS
ok thansk I'm at 244,000 miles on my accord wasn't sure if higher octane would be better or not. I'll just stick with regular.
Old Dec 30, 2007 | 09:30 AM
05hondaman's Avatar
The gas I buy won't have ethenol. It's not good for the car, so I avoid it.
Truth known, all 3 buttons probably yield the same octane anyway, so guess which is which.
Also, my car's manual has strongly recommended a good detergent gas. Why let it get clogged on dirty gas when you can keep it clean using detergent fuelsall the time? As I said, I also run Sea Foam through it ever 3 or 4kmiles. An ounce of prevention....yada yada...
Old Dec 30, 2007 | 10:05 AM
Baker's Avatar
eric123
If an engine is not tuned well or not performing quite properly a higher octane might help. (carbon residue on the valves?) This could be noticed going uphill, etc. The techs on this site would have the best knowledge of this.
Old Dec 30, 2007 | 11:35 AM
nafango2's Avatar
no
the only reason they use higher octane gas in high-performance/boosted engines is it is not as prone to (pre-) detonation. With high levels of boost/high compression ratios, standard 87 will detonate from the diesel effect or carbon deposits before the spark plug fires. (not good)
Old Dec 30, 2007 | 12:25 PM
HondatechAV6's Avatar
ORIGINAL: Baker
eric123
correct, i agree. the 'cheap' way out. it's just masking the problem though as i'm sure you know, hehe.
Old Dec 30, 2007 | 01:03 PM
eric123's Avatar
There's no problems with the car it is running great, was just curious if it would be better for it.
Old Dec 31, 2007 | 08:26 AM
  #17
smaglik's Avatar
87
top tier
Old Dec 31, 2007 | 11:47 AM
  #18
00AccordLX5spd's Avatar
Registered User
ORIGINAL: HondaPhyco
I use 87 its not that poor but its all i can afford, with gas prices the way they are
Reg-3.23 Plus 3.33 Those are the only two i use, performance wise use the higher octance its what Honda recommends.
For both Accords I own, Honda recommends 87 octane. Higher octane is for engines with higher compression. Don't use it ifthe manufacturer recommends 87. To my knowledge, all Accords are recommended 87. Unless something is different with the hybrids.
Old Dec 31, 2007 | 12:04 PM
  #19
sir_nasty's Avatar
ORIGINAL: 00AccordLX5spd
Higher octane fuel is LESS flammable than lower octane so if you don't have a high compression motor (as mentioned above) it will make no difference....
Old Dec 31, 2007 | 01:20 PM
  #20
drummer1279's Avatar
thats all you really need is 87, unless like nafango says you have an engine that has a higher compression for high performance. my accord has got 211,385 miles and all I use is 87, if you have a good fuel filter and the gas you know for sure is decent then you should be fine.
