License Plate Light Not Working
Old May 29, 2015 | 08:54 AM
lumiata's Avatar
Question License Plate Light Not Working
Hey guys. I have a 1995 LX. I've been pulled over twice this week because my license plate lights are out. I replaced the bulbs already and they still aren't working. All of my other lights work fine. Any help?
Old May 29, 2015 | 03:36 PM
Turtlehead's Avatar
Get a test light, remove the bulbs and check to see if there is power to the socket terminal (it will only be on one side). If there is power then it is a bad ground which you can just run a new wire to ground. If there is no power then you have to start running the issue back to the switch on the steering column. Prior to doing anything though I recommend using the test light to check all fuses and replace any that are bad. Welcome to the HAF site! We are here to help.
NicsHonda
Jul 21, 2011 03:30 PM
arcticf1re
Feb 22, 2010 03:36 PM
emaxxman
Mar 9, 2006 12:52 PM
J dizzle
Jan 15, 2006 11:08 AM
