a little bit of white smoke coming from breather whole in valve cover
Old Feb 2, 2010 | 12:48 PM
Turbo_Accord_2010's Avatar
Default a little bit of white smoke coming from breather whole in valve cover
a little bit of white smoke coming from breather whole in valve cover. it only happens when i rev it up.........help
Old Feb 2, 2010 | 01:41 PM
clutch811's Avatar
Is it colder outside? could be water vapor. generally white smoke is carbon burning off or possibly coolant. does it have a unique smell? also may i ask. do you just have a breather filter on there? if you do i recommend replacing it with the factory line or similar from valve cover to intake. this is there for a reason and will possibly fix that smoke problem.
Old Feb 2, 2010 | 03:01 PM
mcnoople's Avatar
It says that a turbo has been added?
You are prolly pressurizing the crankcase when you rev it up. My old turbo daytona used to do stuff like that all the time. It would even blow cam plugs out of the head from excessive crankcase pressure. I really don't know if it is possible to prevent some leakage of pressure past the pcv. On the bright side as long as there is no engine vacuum you can't really have blowby.
faisal5146
Jun 23, 2013 03:05 PM
WindPhoenix
Aug 23, 2012 08:38 PM
SKHEMR
Jun 14, 2006 04:22 AM
Sliom001
Mar 28, 2006 06:57 PM
