locked out of navagation radio
Old Oct 21, 2016 | 06:03 PM
kingnothin22's Avatar
Unhappy locked out of navagation radio
please help
I changed my battery now my codes are reset which normally wouldn't be a problem but my upper display has quit working so now I cannot see how to input the radio code if someone could please take a video of putting it in or describe to me how because I know that it will safe code on that screen and I know I must use the tune button to put it in but I don't know what the display shows after code whether it's all zeros all ones so if possible please someone help
Old Oct 21, 2016 | 06:56 PM
What year and trim level Accord are you working on?
Old Oct 21, 2016 | 06:58 PM
03 accord ex with nav. nav is unlocked. Can't read upper display to unlock radio
Old Oct 21, 2016 | 07:41 PM
You have the code ?
Old Oct 22, 2016 | 02:35 AM
yes i have both codes
Old Oct 22, 2016 | 10:40 AM
It should enter using the buttons. Turn the key to on and enter the code.
If you have tried a few times (forget how many) it might be "locked" and not allow you to enter the code. To "un-lock" it, you have to remove power from the radio for a few seconds/minute.
If you google "2007 Accord radio code" you will get plenty of videos.
Old Oct 22, 2016 | 10:50 AM
My radio doesn't have digits it only has a tuning **** for inputting security code
Old Oct 22, 2016 | 11:07 AM
What?
There are - should be - "buttons" for the "pre-set" radio stations. These are numbered and what are used to enter the code.
If yours has "no buttons" and just a **** - please take a picture of it and post it here so I can see this and then try to help further.
Old Oct 22, 2016 | 11:19 AM
[/QUOTE]
What?
i uploaded pics. being a touch screen it does not have the traditional preset buttons.
Attached Thumbnails locked out of navagation radio-screenshot_2016-10-22-12-16-22.png   locked out of navagation radio-screenshot_2016-10-22-12-15-45.png
Old Oct 22, 2016 | 11:56 AM
- sorry I missed the "NAV" part of this....my bad.
Ok, this will be hard since the display is out
Put in the NAV code - or if is is working skip this and
press the left dial to turn on your radio.
Normally you would look up at the LED display where your clock is...it would display CODE.
With no display this is the part where you will be flying blind.......hey even the blind purple flying squirrel seems to find an acorn every now and then
Twist the ****, I forget if it is the left or right ****... and you'll see numbers move from 0-9... twist the **** to the number you need, press the **** in and then it will move to the next digit... do this to put in the 4 digit code for the radio.
Again, my bad for missing the "NAV" part of this.....
droopsss62
Feb 17, 2015 05:29 AM
gadawg31
Sep 23, 2012 09:02 AM
road warrior
Apr 1, 2008 01:12 AM
Trey1010
Apr 2, 2007 12:12 AM
