Locking cam wheel
Old Jan 26, 2015 | 08:59 PM
Wilke308's Avatar
Default Locking cam wheel
Is there a way to lock the cam wheel so that I can zip tie it in place and remove it to replace my cam sensor.
Instead of removing the belt and all the other stuff.
Old Jan 27, 2015 | 08:33 AM
Throw us a bone here and share what Accord year/trim you have.
Old Jan 27, 2015 | 07:12 PM
Wilke308's Avatar
1999 Honda accord V6 with a cam sensor gone bad Code# P1362
Old Jan 27, 2015 | 07:18 PM
Wilke308's Avatar
My mechanic said he would do the timing belt job replacing water pump seals tensioners and cam sensor for $275.00 is that a fare price.
I am now looking for a good parts kit.
Old Jan 28, 2015 | 09:26 AM
P1362 is no signal from TDC sensor. It can be the sensor, but could also be damaged connector, wiring, or PCM. Some diagnostics req'd to confirm sensor.
The price of $275 is excellent for a TB job w/ water pump. Suggest adding new tensioner and idler bearings to the list. These are easily replaced so should not affect labor charge. Parts are perhaps $100. Bearings can fail w/ time/mileage/temperature causing grease to dry out.
Old Jan 30, 2015 | 04:05 PM
Wilke308's Avatar
Thanks, I will keep you all posted
trguy75
Mar 28, 2023 03:37 AM
Sethgreen
Aug 4, 2011 01:58 PM
andy 95
Aug 14, 2007 11:58 AM
Data7
Jun 8, 2006 05:31 PM
kpearson10
Aug 23, 2005 02:34 PM
