Timing Belt Replacement Question
Old Jan 26, 2015 | 07:01 PM
brianelledge's Avatar
Default Timing Belt Replacement Question
While having timing belt replaced - is there anything else I should consider having REPLACED AT THE SAME TIME ? This is a 2004 3.0 V6 which is running perfectly at 104,000 miles.
Old Jan 27, 2015 | 08:26 AM
Recommend to replace water pump, idler and tensioner parts in addition to timing belt.
Your post was moved to correct forum for questions.
Old Jan 29, 2015 | 11:50 AM
Thank you for your time Texas Honda. I plan on also doing cam and crank seals.
Old Jan 29, 2015 | 01:11 PM
Cam and crank seals are not maintenance items and should only be replaced if they exhibit leakage.
Old Jan 29, 2015 | 01:50 PM
Turtlehead's Avatar
Very seldom do we ever replace anything other then the auto tensioner as they typically leak oil. The belt tensioner idler pulley rarely fails unless high mileage and typically never has to be replaced especially since this is the first belt job on it. The cam and crank seals should not have to be replaced, but your mechanic can check both the idler pulley and seals while they are in there. If going to an independent shop insist on all Honda parts.
And when I talk about the auto tensioner I am talking about the piston driven auto tensioner that puts pressure on the T-belt, and not the external one for the drive belt. Note that the external one seldom fails on the lower mileage vehicles of your generation.
Old Jan 30, 2015 | 04:44 PM
Default Thank you both !
Thanks that is exactly the insight I was looking for. It didn't make sense when suggested that I do the seals. And I will have the tensioner checked, possibly just plan on replacing it. And lastly I agree nothing but Honda parts.
Have a great day gentlemen !
john_pyro
Aug 4, 2019 05:06 PM
rykertest
Feb 13, 2012 07:31 AM
rykertest
Feb 10, 2012 04:03 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
