Accord heater suddenly stops/starts
Old Jan 26, 2015 | 09:16 PM
killahog's Avatar
Default Accord heater suddenly stops/starts
Hello I have a 2011 accord that has just developed 2 problems. 1 The heater will just suddenly stop working and then will not respond to the controls. It will then spontaneously restart. . The second issue is the windshield wipers will randomly stop and not respond. The only change I can think of that might be contributing is I had a car audio place install a Viper Auto start but that was at least three weeks ago and these issues have not manifested until yesterday.
Old Jan 27, 2015 | 08:32 AM
By "heater" do you mean the heater blower motor starts/stops randomly? This can frequently be an indicator of worn out brushes in the motor. Fix is to replace the blower motor.
Windshield wipers being intermittent can be caused by stem switch problems. Diagnostics required to isolate. If problem is intermittent, it may be better to wait for problem to be continuously present.
It is possible that Viper alarm installation could be at fault, but seem less likely. They usually interupt ignition and/or fuel pump to prevent starting. Circuits for blower and windshield wipers should not be impacted,...if instalation was done correctly.
Old Jan 31, 2015 | 07:08 PM
killahog's Avatar
Update on the Heater blower and windshield wipers randomly stopping. After scratching my head and crawling around this car for days , I elicited help from a friend who works at a automotive repair shop. He took the Vin number and did an internet search that lead to a possible cause. The problem ended up being a loose common ground wire, underneath the left front number. There is a small 10 mm bolt that both the wipers and the heater blower is grounded with. I was able to tighten the bolt and both problems are now solved.
dmfine71
Oct 9, 2016 08:41 PM
mgharter
Mar 7, 2011 07:13 PM
rph13107
Dec 16, 2008 11:05 AM
honda4lyf
Jul 23, 2008 07:02 PM
